The budget looks remarkably similar to my '74 build ... :-)
Your Rims and Tires budget is a bit more ... practical. Thanks for the details. |
Not much but I got the power steering box mounted and cleaned up the engine bay a bit. I still need to cut and weld the shaft but I didn't want to drag the welder out just for that so I'll do it when I've got it out for a bigger welding project.
https://cimg7.ibsrv.net/gimg/blazerf...98be13b10.jpeg |
Coming along nicely. Lot of luck to have the windshield frame nearly intact with only little rust.
You sure you need patch panels for the floor? LOL looks more like a whole floor pan. Good continuation with that project. |
Yeah I've seen lots of people with totally rusted out windshield frames so I was happy to find only one little spot. As for the floor they make panels specifically for every location that I have rust and the rest of the floor is really solid. I thought about doing the entire pan but it's double the cost after shipping is figured in (about $1k) and its way more work to keep everything square and lined up so I figure I'll just take my time with the smaller patch panels and hope I don't screw it up lol.
Look who's back in the Chevy world.
(Post 717127)
https://i.imgur.com/6GiQprHh.jpg Thats all for now but hopefully the updates will be more regular and I can start to feel like I am making some progress soon! |
Finally found a little time to spend in the garage this weekend. I got the front clip removed so I would have a little more room to work and this way I can clean up and paint the frame and firewall. This also makes it that much easier to install the suspension and motor. I dropped the front engine crossmember to make it easier to clean up and drill out the u bolt holes to accept the larger 9/16 u bolts.
https://www.s10forum.com/attachments...d-jpeg.337035/ Luckily a full replacement bolt kit is cheap for the front clip! I've got some broken bolt removal to do I guess. Some idiot put those two shiny bolts into the inner fender to fire wall holes and decided to just send it when they realized they weren't the correct thread size. https://www.s10forum.com/attachments...c-jpeg.337032/ After that I pulled the rear axle to clean it up and rebuild. I have the outer bearings and new carrier bearings but I'll need to get new pinion bearings. I probably could have left them alone but if I'm this far in I should do it all I figure. https://www.s10forum.com/attachments...f-jpeg.337033/ https://www.s10forum.com/attachments...6-jpeg.337034/ I still need to clean and de-grease the axle more but this is where I got to today. Hopefully I can keep moving forward and get this thing at least as a roller here in the next few weeks. |
Looking good!
Nice to have room to work. Looking forward seeing it come together again. I guess it will be a while but if done nicely as you do it will be a really nice truck.
Originally Posted by DonL
(Post 717582)
Looking good!
(Post 717589)
Nothing much to update other than I got the axle bearings removed last night after receiving my bearing and race driver set from Amazon yesterday. I almost ordered the proper bearing removers and slide hammer but I figured I would see if I could make this work and I'm really glad I saved the money! I slide the driver inside the tube followed by a piece of scrap 1x2 and three wacks with a dead blow and the bearings popped right out. https://i.imgur.com/MCBhfOfh.jpg |
| All times are GMT -5. The time now is 04:36 PM. |
