-   Builds (https://blazerforum.com/forum/builds-48/)
-   -   Putting a lift on my jimmy (https://blazerforum.com/forum/builds-48/putting-lift-my-jimmy-69538/)
Jimmy_Blazer 03-30-2012 11:39 PM
I have a 95 4wd, 4 door Jimmy. I am going to put a 2 inch body lift and do a 2 inch suspension lift using torsion bar keys for the front. As for the rear I am undecided if I should use lift shackles or add-a-leafs. I know with the body lift the shackles would show more. I am unsure of what I should use. Opinions please?
atvwarrior 03-30-2012 11:56 PM
I would say this has to be your call man , only you know what you'll like , How ever since your asking for opinions I would use the lift shackles . Have you been reading the other suspension lift builds , it don't sound good . I to was going to go with a suspension lift but I decided to go with a SAS instead check out my build thread the link is in my signature.
jimmy2000 04-05-2012 05:00 PM
if i was u id use add aleafs due to leaf springs become soft with age althouth on my 200 jimmy i used both 2 in add a leaf and 1.5 inch shackle gave it that zr2 look
