RC 2.5 Lift???
I plan on putting a lift on my blazer this summer, its the 4 door 4x4. I only want 5-6 inches but not as a whole lift, I plan on doing the 2 or 3 inch body lift and a 3 inch suspension lift. I know you can do up to 3 inches with new torsion bar keys, but it also puts stress on components such as the ball joints and CV shafts. I think I have 2 options for the suspension lift. 1.) get this get from rough country
Chevy / GMC Suspension Lift or 2.) buy torsion keys from eBay ($50) and I already have shackles and get ball joint spacers to reduce the wear on them (the top ones anyway). Which one should I do? If all else fails I'll just do the 2-3 inch body lift and maybe do a torsion crank. Point is will the ball joint spacers substitute for the new control arms from the actual kit? I know I will have to get new shocks, just trying to compare prices and save a little bit. |
Originally Posted by Jimmy_Blazer
(Post 499883)
Chevy / GMC Suspension Lift or 2.) buy torsion keys from eBay ($50) and I already have shackles and get ball joint spacers to reduce the wear on them (the top ones anyway). Which one should I do? If all else fails I'll just do the 2-3 inch body lift and maybe do a torsion crank. Point is will the ball joint spacers substitute for the new control arms from the actual kit? I know I will have to get new shocks, just trying to compare prices and save a little bit. https://treadwright.com/p-61-265-75r...dog-m-t-e.aspx thats about 6-7 inches higher than stock I will post pics after the tires are on. It already sits quite high but it will be even higher after the tires. |
How much do you have the t-bars cranked to? Have any problems with anything wearing out??? Thanks for the tire link I was wondering where I could get some decent tires without breaking the bank
(Post 499956)
OK thanks, do the lower and upper wear evenly? I imagine the ball joint spacers will help as if the RC upper control arms would. I dont plan on doing much wheeling I just need a taller ride for all the snow we get where I am. Once I get enough saved up hopefully by next year I will do a solid axle swap.
I replaced them both at the same time so not sure which will wear out first.
pics of firebird rims with treadwright 265-75-16s (32.2inch tires) http://i889.photobucket.com/albums/a...4302/32s12.jpg http://i889.photobucket.com/albums/a...302/32s121.jpg http://i889.photobucket.com/albums/a...302/32s124.jpg http://i889.photobucket.com/albums/a...302/32s123.jpg Before with just the body lift and keys http://i889.photobucket.com/albums/a...2/IMG_3105.jpg after with tires and rims http://i889.photobucket.com/albums/a...302/32s125.jpg |
