Red Riding Hood (95 Blazer build)
Old Apr 13, 2015 | 12:35 PM
  #51
jbrooks19's Avatar
jbrooks19 is on a distinguished road
Got my switch panel installed and wired
Old Apr 14, 2015 | 04:43 AM
  #52
Red Sled's Avatar
Red Sled is on a distinguished road
Enjoying reading your updates! Whats next????
Old Apr 14, 2015 | 08:08 AM
  #53
jbrooks19's Avatar
Here is a "To Do" list i keep. Still adding stuff to it as i think of it.
Repair or replace heater core cover
Add-A-Leaf in the rear
Upper control arm (Drivers side)
New Batteries (2 batt)
Ball Joints (Not needed, just replace as a preventative measure)
AC
Trans flush
Tarp Canopy (PVC Pipe and tarp)
Power Inverter
Power outlets in the back.
Battery backup.
Bedline rocker panels (Remove trim)
Spotlight
12v Air Compressor
Build box for back (Wood with compartment and the cover in carpet)
Rebuild Transmission
Convert Vacuum actuated front diff to cable
Install new Transfer case switch (Dorman 49315)
Completed:
*Extra Lighting (Side facing LEDs on roof rack, rear facing LEDs, camping lights on hatch) DONE 4/7/15
*Service rear diff (80w 90) Done 3/15/15
*Shift issue Steering column shift assembly DONE 3/15/15
*Shift Cable replaced DONE 3/15/15
*Thermostat gasket DONE 31515/15
*Wheel spacers for the rear (2in) DONE 4/7/15 (REMOVED DUE TO VIBRATION)
*Tire Plug kit BOUGHT 3/15/15
****THIS WAS ADDED BY ACCIDENT, BUT SINCE I ADDED IT, I'LL LEAVE IT****
Connecting batteries in series does not increase the capacity of the batteries; it simply increases the overall voltage to meet your system requirements. Once your voltage requirements are met, if space allows you can double the batteries in a parallel connection- thereby doubling your battery capacity.
Series Connect
To increase voltage, connect batteries in series. This will not increase the system capacity.
Example :
Two T-105, 6V Batteries rated at 225AH Connected in Series
System Voltage: 6V + 6V = 12V
System Capacity = 225AH
Parallel Connect
To increase capacity, connect batteries in parallel. This will not increase the system voltage.
Example :
Two T-105, 6V Batteries rated at 225AH Connected in Parallel
System Voltage: 6V
System Capacity = 225AH + 225AH = 450AH
To increase amp-hour capacity,
Series/Parallel Connect
To increase both voltage and capacity, connect additional batteries in series and parallel.
Example :
Four T-105, 6V Batteries rated at 225AH Connected in Series/Parallel
Old Jun 3, 2015 | 02:36 PM
  #54
jbrooks19's Avatar
Got my new tire carrier picked up and painted/mounted. Very, very happy with it..
Old Sep 16, 2015 | 08:54 AM
  #55
jbrooks19's Avatar
Well guys, the Blazer found a new home. It got to the point where i was replacing parts or fixing something on it about every week, it was just too expensive to keep.
So, it was replaced.... Meet Red Riding Hood, the second. It is a 2004 Jeep Grand Cherokee Limited Edition has the 4.0 and is very, very clean.
The pic is after a 2in lift, bigger tires are coming this week.
Old Sep 16, 2015 | 09:19 AM
  #56
HARDTRAILZ's Avatar
HARDTRAILZ is on a distinguished road
I did not get out there to get a pic of the tires...did you find others?
Old Sep 16, 2015 | 11:50 AM
  #57
jbrooks19's Avatar
A friend of mine has a set of BF Goodrich AT on 17in wheels, I am supposed to be going up to ft wayne friday to get them. He is a flake though so I guess we will find out. If he flakes out then i'll probably still take yours.
92blazin
Nov 2, 2010 03:25 PM
ChevyBlazerChick
Sep 10, 2009 05:23 PM
ghost
May 20, 2009 03:36 AM
92 blazin
Feb 25, 2008 08:55 PM
dbleon
Jan 15, 2008 04:50 PM
