s10 blazer sas
im wanting to get a s10 blazer and sas it, its gonna be for the trails only, ill drive it on road tho to the trails, i planned on running a dana 44 front and like ford 9" rear and run 35s and i guess try to find some dodge dakota leafs from like lkq, so i just gotta find any dana hp 44 thats around 60" wms to wms? or do i need to run a certain dana hp 44?
Narrow-track Wagoneer axles are pretty popular. They're widely available, relatively cheap, and pretty close to the right width, though I don't know exactly how wide off the top of my head.
Originally Posted by Tom A
(Post 695962)
You might have to keep an eye out for a bit. They're out there. Make sure you get one with the differential on the proper side, or you'll have to change the transfer case. Scout axles will also work, but they're much harder to find than the Waggy ones.
I don't know where you're located, but I got one once from a Jeep-only junkyard near Sacramento (J&W Jeep). They have anything you could need. As far as gears go, 4.56 or 4.88 would probably be pretty good all-around with 35s and an overdrive transmission. |
(Post 695967)
what year dodge dakota should i get leaf springs from? is there any other springs i can use? besides rancho, what length springs should i use?
thanks |
I think any second generation Dakota rear springs will work. I'm running full-size Chevy lift springs, front and rear (47" front, 52" rear) with one front leaf removed and the bottom overload leaf removed from the rear.
okay so should i run the rear dakota springs for my front and rear or will i need different length springs front and rear?
thanks |
Yup, run those on the front. I think the pin offset is too much for the rear unless you want to stretch your wheelbase. The stock springs will work fine in the rear if you put them over the axle and keep the front height reasonable. Or you can use 52" full-size Chevy springs, which I believe will move the rear axle back one or two inches.
| All times are GMT -5. The time now is 07:04 AM. |
