Reload this Page >
Swapping to ZR2 rear axle
Community
Search
Old 10-22-2010, 04:24 PM
you just have to keep pounding on it with the pry bar until it comes loose
Old 10-23-2010, 03:07 AM
rob44_90's Avatar
rob44_90 is on a distinguished road
Alright, I'll just beat the CV to death with a sledge hammer and see what happens.
This axle is sooo much better than the stock axle. I've noticed an improvement on handling and ride comfort.
Old 10-24-2010, 10:22 PM
rob44_90's Avatar
Well, I beat the crap out of the CV and still couldn't get the thing to budge. Is there a clip inside the diff, holding the CV in place?
Old 10-24-2010, 11:02 PM
b1heqh54's Avatar
b1heqh54 is on a distinguished road
Disconnect the left side wheel drive shaft from the differential carrier by placing a block of wood or a brass drift against the tripot housing. Firmly strike the block of wood outward from the case with a hammer. Strike hard enough to overcome the snap ring pressure holding in the shaft.
Old 11-05-2010, 11:56 AM
nimblestix is on a distinguished road
hey i apologize for ignorance, but im unfamiliar with your build...
so to help me better understand, did you install zr2 front and rear diffs/axle on a non-zr2 blazer?
Old 11-05-2010, 12:46 PM
I'm pretty sure he only did the rear axle swap. another member wolfpack swapped both front and rear axles I believe
https://blazerforum.com/forum/general-chat-34/zr2-ed-49901/
Old 11-07-2010, 11:50 PM
rob44_90's Avatar
I only swapped the rear axle for now. With the Tru-Trac limited slip I honestly don't need 4x4 for what I mud in,if you get a limited slip definitely get an Eaton Detroit Tru-Trac. I put a lousy 23 second video on youtube of me doing a quick mud burnout on the side of a road (phone died before I was done messing around). Same day I broke a cv. Here in a week or so, I'm gonna swap the front diff and put on all new cv's, balljoints, tie rod ends, pitman arm, and new spark plugs. Can't wait till it's done!!!! Oh, and a 1" t-bar crank so I stop cutting my nice tires up.
Old 11-08-2010, 07:02 AM
djerock's Avatar
djerock is on a distinguished road
looks good can't wait to see more.
Old 02-08-2011, 01:05 AM
TreasonAgainstCaesar's Avatar
TreasonAgainstCaesar is on a distinguished road
Nice swap. Did you ever finish this?
Old 03-19-2011, 11:50 AM
rob44_90's Avatar
Yea, I finished everything a while back. I also put in the front ZR2 differential. Sorry I didn't post back up on this. Only problem was my front drive shaft CV broke about a month after I got the front diff put in, so no more 4x4 until I get a new one. And they cost a ridiculous $140 a piece.
Quick Reply: Swapping to ZR2 rear axle
