Tank
So this is the start of a new project. What I started with, stock.
What I have done... AirRaid Cold Air Intake AirRaid throttle body spacer Cherry Bomb Hi Flow Cat Delta 40 Flowmaster Muffler Descreened MAF Removed Throttle Blade Diffuser 31" Goodyear Wrangler A/T Chopped 36" off exhaust Gabriel Max Control Shocks What I have planned. Accel Coil and rotor ECM Tune 3" lift P&P heads bigger valves hedman headers body work bigger flares SFA swap and of course lobby congress to have emissions removed from my vehicle. More pics to follow as i have already done more work. https://blazerforum.com/forum/pictur...ictureid=11031 |
Good build so far! I wanna see more pics of that hood.
When I got the truck it had these scoops on here. They were for decoration only, not cool. So I cut through the fake screens and started cutting holes through the hood. The plan being to hook the intake to them. I am still fabricating new screens to put in front and still working on the air box to connect to the hood.
https://blazerforum.com/forum/pictur...ictureid=11034 |
https://blazerforum.com/forum/pictur...ictureid=11035
with new shocks and undercoating along the side. I still need to undercoat the fender flares and both bumpers. Also putting a 2 inch lift on next weekend. https://blazerforum.com/forum/pictur...ictureid=11036 I have some of the interior out right now for painting. Will post when done. Also pulled the tow hooks off to give them a coat of fire engine red. |
cool project so far man, how did you descreen the maf?
Originally Posted by Project_95_Blazer
(Post 352069)
Originally Posted by wreckhur
(Post 351996)
Needle nose pliers on the MAF. Rust-Oleum ford red ceramic engine enamel. I used the engine paint because it dosent chip off. Also for plastic you might wanna use a filler primer to smooth out the dimples in the plastic.
okay thank you
So of course it rained about an hour and a half after applying another coat of undercoating to the trim and sides, why do weather men get paid again? Anyways have some more pics up this afternoon.
| All times are GMT -5. The time now is 10:30 AM. |
