8 Attachment(s)
Part 3
New amp dc audio 12k Attachment 32156 Attachment 32157 A bunch of random car audio stuff in the spare bed room Attachment 32158 Now I did clear needle mod Attachment 32159 Attachment 32160 New batt and amp rack started Attachment 32161 Attachment 32162 And new air shocks just showed up Attachment 32163 |
So the biggest news about this build is I'm saving for a jeep and idk what I'm doing with the blazer
What kind of resin are you using, Otho, Iso? Any DMA with the catalyst I see the modified pillars covered in a light weight cloth,what you laying up under that,matt. Finish with matt and veil? How many layers? Brush it? Rollers? Both? Curious?
I'm using normal 3m resn and normal Mekp
No Dma I used spandex pulled tight then I layed the mat ontop I do about 5 layers usually and I use a brush |
Originally Posted by killallblue
(Post 551819)
Yes spandex the clothes I pull them tight ca glue it how I want layer the resin let them dry then I lay mate I do about 5 layers depending on the shape and how thick I want then I do a first trim then sand sand sand trim bondo sand sand sand then paint and I was going to post this part I hate the 3m but I had some left over I like the us composites resin that's ****a legit
(Post 551860)
Sorry if I forget anything im a lill drunk
In order 1.spandex gets my shape I want 2.nah the resin doesn't lay in the low spots I set it up a lill hot 3.nope no melting of the spandex and tbh it was the first time using spandex I usually use fleece for pods like those Tahoe pods in those pics 4.this isn't a mold so need for wax I did do that before off those pods for the Tahoe 5. Thanks man I'm still a noob so I try Im certified mecp for 12v but that dosnet teach you fabrication 6.led mod was pretty easy on the cluster the switches were harder but a dremel and ca glue and solder iron its easy |
(Post 552130)
Well build is over I bought a 02 grand Cherokee and a 4" long arm kit for it already
| All times are GMT -5. The time now is 06:38 AM. |
