5 Attachment(s)
Deleted
6 Attachment(s)
Deleted
Can't wait to see the start of you install. I do not suggest you install your rims because they are only 7" wide and will rub on your sway bar. Also some tire manufactures require wheels to be 8" or wider. You might wanna check with them as to what they reccomend. Also, did you get a power programmer so you can recalibrate your speedometer? It will be off when you install those larger tires.
1 Attachment(s)
Deleted
Spacers are scary but those z28 wheels are good. Hopefully UPS hurrys up and brings you your kit today.
Deleted
you could always look at the older z28 wheels that are only 15 inch. I think they look pretty good on a lifted truck
11 Attachment(s)
Deleted
looking forward to see how it looks. I've been swaying towards getting a trailmaster over a superlift
Trailmaster isn't bad. At least the parts are labeled.
| All times are GMT -5. The time now is 08:09 AM. |
