Finally decided to go to top terminals. I got a deka second line agm 34 group for $62 from deka depot here!
https://cimg7.ibsrv.net/gimg/blazerf...fca685bcd9.jpg Adding a run off 6 gauge from main fuse to fuse box and from main fuse to battery. Interior lights are little brighter. https://cimg8.ibsrv.net/gimg/blazerf...76fef5d947.jpg https://cimg9.ibsrv.net/gimg/blazerf...3cda40d696.jpg New and old |
Looking good. How are your home mad hood vents working out?
Better than i thought..i will definitely cut out the holes bigger soon. After about 30 mins , the hood is barely warm to the touch, but the vents hot! I wsnt to add one in between the window fluid sprayers. I will be doing alot for cooiling over the next 2 months
Picked these up for 10 bucks as makeshift traction aids...used them with anchor pins. They work decent, might add snow studs to them later
https://cimg7.ibsrv.net/gimg/blazerf...234b667056.jpg Gave it a good wax with griots 3 in 1 ceramic. It came out really good. https://cimg3.ibsrv.net/gimg/blazerf...b152088d89.jpg |
Went to tractor supply and got some u bolts to mount them, and i used some mini straps from work for shovel and a old gun lock.
https://cimg1.ibsrv.net/gimg/blazerf...489dd9f978.jpg https://cimg4.ibsrv.net/gimg/blazerf...6cd96dd85e.jpg |
Got bored and wanted some extra power oprions for my drills and work equipment. I set a budget for myself which was 40 bucks. A yard sale or 2, scraps from work....and magic!!
https://cimg7.ibsrv.net/gimg/blazerf...e936408230.jpg The white and green 12 awg and tied into my secondary fuse panel. https://cimg1.ibsrv.net/gimg/blazerf...f9767ffa95.jpg 2 sealed agm fire alarm batteries from work https://cimg4.ibsrv.net/gimg/blazerf...ea9e2cc7ee.jpg https://cimg4.ibsrv.net/gimg/blazerf...ca55e04ef1.jpg https://cimg2.ibsrv.net/gimg/blazerf...2e6d396d0b.jpg |
Did some repairs the last 2 weeks. Front shocks, front brake pads, rear pads and rotors, fuel pump, copper distributor cap and rotor, cat delete, and a front end grease
https://cimg2.ibsrv.net/gimg/blazerf...943bd39c13.jpg https://cimg4.ibsrv.net/gimg/blazerf...ebe6cc417b.jpg https://cimg5.ibsrv.net/gimg/blazerf...83314394fb.jpg https://cimg7.ibsrv.net/gimg/blazerf...dcd548aa50.jpg https://cimg9.ibsrv.net/gimg/blazerf...3872cd176a.jpg fuel tank was a b**** alone. Lesson learned drain gas tank!! |
Finally did the throttle.body mod, only took 20 mins. I enjoy the extra pep off the line. Wasnt too touchy like some people described, it was just right. Also dropped my bland filter with a low budget performance filter (UPGR 8). Its running great
Here's some sound vids of the cat delete
Added some new grille lights. Eagle eye leds kept going out. This time i used trailer amber leds and rock lights. I wire them on a relay as well. Im also starting on my second battery box as well. A 51r fits well in jack location.
https://cimg0.ibsrv.net/gimg/blazerf...f4d805d6ae.jpg https://cimg6.ibsrv.net/gimg/blazerf...54cae81bd1.jpg https://cimg2.ibsrv.net/gimg/blazerf...3ae100d492.jpg https://cimg5.ibsrv.net/gimg/blazerf...d8dbb46185.jpg 51 r agm reconditioned https://cimg2.ibsrv.net/gimg/blazerf...52c0d390ce.jpg https://cimg3.ibsrv.net/gimg/blazerf...e56287e74b.jpg |
| All times are GMT -5. The time now is 06:34 PM. |
