the work on the blazer
4 Attachment(s)
well to start off I got the blazer for 500 with the "hard start problem" and the 4x4 not working completely and needing new rubber.
well this is the "build" of the blazer it will be nothing like the others but it will keep you up to date on what it will have. attached are the pics I have from my phone so ignore the quality or lack there of. so far it has new rubber all around and TA snowflake rims new bat and cables headgasket kit ported/smoothed TB 3.5 in CAI electric fan 180 tstat ac delete (system was dead anyway) gasket matched heads/lower intake wire wheel polish job on all alum upper parts custom 2.5 in exhaust (perks of having an exhaust man next door) the plans I will go with the K.I.S.S methodology here poly bushings to include engine mounts and all suspension t-bar crank to 1.50 in 2 in shackles in the rear fluid flush and top end clean NOT going to do a body lift maybe a portable nitrous setup to see what she can do on the bottle tune with tunercats if they support it (buddy has a tunercats setup) grand cherokee mod i need a tighter steering response I hate slop more pics will come later as it gets all done |
| All times are GMT -5. The time now is 03:50 AM. |
