Cloudy paint
Paint job on my 94 is cloudy. Looks great when it's washed and waxed, but then the cloudiness comes back after a while. Can someone recommend a product for me? Thanks.
rubbing compound
rubbing compound. (THIS IS NOT LIKE WAX). You carefully and it will remove the oxidation that is causing the cloud. Wipe in small corner and clean off. See if it is clean. If so. Do rest of vehicle. Don't get carried away. You can actually clean it to well. Then follow up with coat of wax. First wash dirt off before you start and take your time. I had a 83 blazer that looked dual. So I used some rubbing compound and waxed it good. After I got the exhaust fix. People didn't believe it was a 83 since it ran and purred good. Also chrom polish for the chrome and unelss somebody else says differnetly. A temp fix for the traditional s10 blazer molding first gen modules. Use black shoe pollish. You know the type in the bottle with sponge on the end. Last for about 1-3 months.
Josh |
| All times are GMT -5. The time now is 05:25 AM. |
