Rear Body Pillar question
So I`ve read on here a few times about that Black part on the truck next to the rear glass that discolors/fades and wondered this... What about using the Truck bed coating to give it that `thick Plastic Look` again? I`ve got the spray and I'm just curious, once we get a day above 65*, how this will work.
Has anyone else tried this? Since mine is a 1995, it`s discolored pretty badly. http://i297.photobucket.com/albums/m...r/100_5307.jpg It`s the only ugly thing left on the truck! |
RE: Rear Body Pillar question
You should do the tire carrier and the pillars in bed liner[8D]
I had the same problem on my 2000 2 dr. Minelooked identical to yours. One solution I tried was sanding off the rough plastic to smooth it some. Then I masked it off and sprayed on a couple coats of a spray paint designed for plastics. It turned out ok and it looks tons better then before.
post pics when its done, i am starting to see the gloss on mine wearing away
ORIGINAL: stevo post pics when its done, i am starting to see the gloss on mine wearing away |
Wonder if your solutions would work on the removable tops of a K5?
It is a matter of plastic vs. fiberglass. The tops on the K5's were fiberglass with a top coat.
