180 stat
Old Oct 29, 2004 | 01:59 AM
timetoblaze's Avatar
timetoblaze is an unknown quantity at this point
Default 180 stat
im having trouble finding a 180deg stat for my 99 4.3l anyone have one or know a site i can find one for cheap? any help would be appreciated
Old Oct 29, 2004 | 06:05 AM
01xtreme's Avatar
01xtreme is an unknown quantity at this point
Default RE: 180 stat
Any auto parts store should carry them or check out www.stylinconcepts.com I saw one on there that I wanna get for $13.
Old Oct 31, 2004 | 01:54 AM
2001Blazer4x4's Avatar
2001Blazer4x4 is an unknown quantity at this point
i have one sitting home for a 2001 that i am not using. My hypertech programmer said not to use it, but they sold it to me with the programer. its for 180. would u hapen to know what is the stock rpm rev limiter on the 2001 blazer 4x4. i need to know for adjusting it on he power programmer, what is the highest safe rpm i should use, and what speed at shift point is good
Old Oct 31, 2004 | 06:13 AM
01xtreme's Avatar
96 or 97 mph I belive is the stock rev limiter. Ask timetoblaze...he has a power programmer and all sorts of other gadgets under his hood. he should be able to point you in the right direction.
Old Oct 31, 2004 | 01:21 PM
yeah it should be around97-98 .... do you have a man or auto tranny..... my auto i just put on the firmest ... wont hurt it as long as you dont beat on it everyday....like take offs etc.... ...as for the 180 stat if the company sold it to you i would imagine its safe to use...im about to put one in my blaze.... i dont really see a reason why you wouldnt be able to use it its gunna keep your engine cooler and help with engine wear..... but thats just my 2cents
Old Oct 31, 2004 | 01:22 PM
also you know that you have to run your reg gas down to about empty and put in 93 or any higher grade than reg before doing to the tuner or you will get pinging and no one likes a pinger.....
Old Oct 31, 2004 | 10:44 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
ORIGINAL: 01xtreme
i don't mean to be a dick, but 96 or 97 mph would be the speed limiter. the rev limiter limits the rpm's of the motor. say you manually select 1st gear, floor it, and forget to upshift, you won't float your valves or blow your motor. sorry, i couldn't help it[sm=smiley24.gif]
Old Nov 1, 2004 | 07:24 PM
01xtreme's Avatar
That was my mistake....I misread it.
Old Nov 11, 2004 | 03:09 PM
well if u guys just relized the mistake fix it haha, what is the max stock RPM, if you dont know plses do this for me. Put ur automatic in first gear and go full throttle and tell me were the tac lands. I set mine to 5,500 rpm'. is that to high??
Old Feb 18, 2005 | 04:18 AM
benzodogg's Avatar
benzodogg is an unknown quantity at this point
Max stock rpm on the blazer is 4600rpm, at least thats what mine was. I reprogrammed to 5300 i believe. Setting it too high can put wear on your engine if u plan on stomping it a lot.....
lecktrix
Apr 2, 2012 10:48 PM
Hezzu
Jul 17, 2011 05:09 AM
markblazersf
Sep 15, 2010 12:49 AM
PaulO2288
Aug 26, 2009 03:04 PM
2001Blazer4x4
Engine & Internal
Feb 18, 2005 04:07 AM
