1985 GMC jimmy s-15 4x4 2.8l motor help
Old Dec 11, 2011 | 09:04 AM
neo71665's Avatar
Carb rebuild kit
Old Dec 11, 2011 | 09:11 AM
abig84's Avatar
Originally Posted by neo71665
Carb rebuild kit
this.
you can probably send it in.... i know like on the aftermarket edelbrocks you can just take off the top of the carb and replace that. you might get lucky. see if it looks like you can just take off the top plate of the carb. then do it the lazy way. buy the rebuild kit and just use the accelerator plunger
Old Feb 27, 2012 | 09:30 PM
Hard Driver's Avatar
Hard Driver is on a distinguished road
Their are weber down draft two bbls one has a progressive secondary and the other isn't progressive that can be used on your manifold,can't remember if an adapter is required I believe it's a bolt on for the stock manifold.If your lucky you might run across one at the wrecking yard or on craiglist / ebay.
Old Feb 28, 2012 | 11:07 PM
84BlazerS10's Avatar
Yeah, I have owned my 84 blazer s10 for over 3 years now but it's currently in the process of being repainted but most of my problems have been carburetor related.
Old Mar 1, 2012 | 01:37 PM
neo71665's Avatar
Ive worked on weber carbs. Your lucky if somebody has taken a hammer to those pos before you seen it.
eilax53
Apr 18, 2012 02:05 PM
Advantage049
Feb 11, 2011 04:59 PM
rugerfierro
Jan 23, 2011 07:46 PM
londonmazda
Oct 19, 2010 02:15 AM
PROJECT85K5
Dec 5, 2009 09:14 AM
