-   Engine & Internal (https://blazerforum.com/forum/engine-internal-9/)
-   -   1994 blazer tahoe 4.3 vortex w series (https://blazerforum.com/forum/engine-internal-9/1994-blazer-tahoe-4-3-vortex-w-series-16497/)
redneck 01-21-2008 12:34 PM
I have no power once ir warms up it keeps boggin out then it takes a few min before it restarts
I have replaced the injectors the spider tps iac plugs cap rotor fuel pump computer and prom
egr map fuel filter firing order is right I replaced the distributor also cn anyone tell me what I can do now to get this thing to run right
HeyYou 01-21-2008 02:23 PM
RE: 1994 blazer tahoe 4.3 vortex w series
Have you checked the catalytic converter?
SES light on?
Chevy Lover 01-21-2008 11:56 PM
I'm thinking possible plugged exhaust. Try pulling out the O2 sensor and running it.(to test)
thegr81 01-22-2008 02:39 AM
ORIGINAL: Chevy Lover
Would be the faster way to test for a plugged exhaust, and also the cheapest!!
redneck 01-22-2008 12:48 PM
converter is good o2 senseor is brand new
94blazer4.3ho 01-22-2008 02:46 PM
have you check for compression? in all cylinders.
you said you replaced yourfuel pump did you make sure fuel pressure is around 50psi-60psi running/off? maybe falty pump.
any check engine lights? codes? is the timming correct?
good luck
rriddle3 01-22-2008 03:23 PM
This just sounds like a typlical ICM failure to me. Check this thread and see if you get the same impression.
