2.8l Hop-up
Hey, I've got a '86 S10 Blazer w/ 2.8 throttle body injected and auto trans. Anyone know what I can do to upgrade her for just general drivin? I plan on doin a long haul to Miami before to long and I want to have her ready for the highway. Any and all opinions will be considered.
Oil change, check all your fluids, check your tires, tune up if need be, make sure nothing's leaking or making funny noises.
there really isn't any "upgrades" for a 2-8.
Matt has pretty much covered all that you can do. |
can u swap out the heads and whatnot from a bigger 60*v6? is that a 60*? if so does it have the same bolt pattern as an LQ1? i know that wouldnt be the best motor for 4x4ing, but for a street truck that wouldnt be bad with a turbo!! lol
hey we can all have dreams. :D |
while i know the 3-1 guys drop on 3-4 & 3-5 upper ends on them, i don't know how well it would work on a 2-8.
might have some shrouding issues on the cylinder. |
i know fierro guys take out the 2.8 in favour of LQ1s, but i mean you dont really need torque when your car weighs less than your tank of fuel.
IIFC the LQ1 has 220hp and 180ft/lbs, but the power doesnt arrive till like 3500rpm, mind you you still have another 3500 to go before you get to the redline on the stock motor. |
Thankx
Hye guys, thanks for the info. In regards to doin basic maintenance, I have already done the basic tune-up (sort of) and was just lookin for a way to bolt on a few more horses and ft/lbs.
put on an electric super charger... that way its more efficient at idle. :P
Years ago I had put a turbo on my old 86 tbi 2.8 it had a little more kick @ 5 lbs. it was fun for a second. If you just want a few basic mods just improve t he air intake and add a exhuast. I don't really even like flowmasters but on the 2.8L the flowmaster sounds the best. My cousin rebuilt a 2.8 a couple years ago with forged higher comp pistons, small cam, ported heads. It had a tiny bit of umpf buit not much more.
To the OP if you want to do some upgrades to your 60 degree I suggest joining up on a forum that knows more about them than just what they have heard or read. www.60degreev6.com
also read up on the mods and links at the bottom of this page http://members.shaw.ca/betterthanyou/
(Post 414547)
Yawn, all kinds of stuff you can do. From simple bolt ons to full out. Most people don't think much of them because of the problems they had in the early 80s. They have evolved to be a pretty good engine and popular in some classes of sprint cars. About any upgrade for a 4.3 there is for a 60 degree. Everything from cams, roller rockers, to superchargers. Plus you can always do like they did before you walked into a store and ordered parts, make them if you have the skills. The aftermarket has ruined people and made them lazy. Honestly do you think the old timers at the salt flats went to the store and bought an adapter to bolt an Allison v12 to a model t trans?
Originally Posted by BlazinClinton
(Post 414557)
hey we can all have dreams. :D 1986 and newer RWD iron heads are all the same, 2.8 - 3.1- 3.4 all use the same casting. As for it being in a 4x4 I have no complaints. My 3.4 will run circles around all the 4.3s around here in the mud and get better gas mileage doing it.
(Post 414607)
might have some shrouding issues on the cylinder. Referred to as the 3x00 swap and not something I would suggest to somebody unless they are a good mechanic. Not hard to do but requires the correct pistons and the FI system has to be swapped over.
(Post 414635)
Originally Posted by boostedretard
(Post 415093)
Not a big fan of boost on 4x4s, water and mud tends to make problems. I've done just about everything one can to my 3.4 in mine and it puts out 183hp on TBI with the stock chip. Some custom chip work I'm sure I could beat that but I'm more worried about SFA and at least some 35s so I'm building a 5.7 for it right now. Gonna keep the 3.4 for my noma to toy with. |
The LQ1 is a better breathing engine than any of the other 60*v6s offered during its time, and with minor timing work you can really get these motors woken up, even during testing time while the motor was in the works it was reported as having over 260hp! but got toned down for reliable use.... that could be the key words right there but i happen to know from owning one of these and having friends who have done all sorts of shtuff to their engine that these things can keep up with a newer GTP in a four door old school ass grand prix! i really should get a pic of his motor, hes on 60*v6.com as HayesPerformance. ask to see his GP engine. you will be amazed.
there are options for the motor and if you ask me its alot nicer of a looking engine than the other ones offered in its time, and even the L67 doesnt look near as good to me. plus push rod engines have had their time havent they? do we still use underhead cams?? the LQ1 has a timing belt :) one that is a PITA to change but nonetheless its still there... i wouldnt say its a good motor for a 4x4 but for a street truck, it would be pretty sweet, plus in the engine bay of a S series you would atleast have the needed room to work on it if need be, good luck working on it in a fierro or any FWD application |
Hey guys, I'll check it out when I can. Thanks for your help. Some new pics will be up by the end of the week, or you can check out Deviantart for pics of the engine. Search JazzyMan223 for the pics.
(Post 415455)
there are options for the motor and if you ask me its alot nicer of a looking engine than the other ones offered in its time, and even the L67 doesnt look near as good to me. plus push rod engines have had their time havent they? do we still use underhead cams?? the LQ1 has a timing belt :) one that is a PITA to change but nonetheless its still there... i wouldnt say its a good motor for a 4x4 but for a street truck, it would be pretty sweet, plus in the engine bay of a S series you would atleast have the needed room to work on it if need be, good luck working on it in a fierro or any FWD application They had their place and time granted, but even GM dropped them because of the troublesome designs. I've been over on 60 degree for years and know who you are talking about. I'm still waiting on Brad to get finished with the 60 degree full race rustang over there. My point still stands as its a FWD engine and would require many mods to fit in a 4x4 s-series. The starter is on the wrong side, the oil pan would have to be cut up so much to clear everything. Might as well do a 3x00 swap and figure out a way to bolt a m90 on the top of it. You can keep the bottom end but jump the HP way up there. Dropping a DOHC or a 3x00 is nothing I would suggest anybody but somebody with lots of mechanical skills under their belt to do. |
some guys LIKE a challenge though, and some people really LOVE that motor...
(Post 416366)
More power to ya'll. The one I owned wound in a junkyard and you won't have to worry about me taking any more from you guys. We had less issues out of my uncles ford 427 sohc in his crappy rustang. I think I still have the tools to set the cams in the shop somewhere for that 3.4 dohc, they supposed to be getting hard to come by now if I understand right. |
