4.3 Spark Plugs
Old May 14, 2010 | 03:40 PM
XtreemeBlazer's Avatar
XtreemeBlazer is on a distinguished road
Great something to look forward to cant wait. LOL Do you still have to take the tire off to reach it when you take the steering shaft off?
Old May 14, 2010 | 06:42 PM
EzTec's Avatar
EzTec is on a distinguished road
The way I did it, was get the plug socket on and get out a 1/2" box end wrench and used the wrench on the end of the socket. I worked it out slowly, but once it was loose, i worked it with my fingers. Probably took me about 20 minutes to get it done, an hour overall for all 6 plugs.
Old May 15, 2010 | 01:21 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
I'm a through the wheel well guy. I love to change the plugs and yes I'm not well either if any of you have read my posts then you'd know. I'm with you Ohsofly my brother.
Old May 15, 2010 | 07:39 AM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
It sounds worse than it is, I have never removed the steering shaft just long extension and a universal comes right out (although my steering shaft is at an altered angle go go 3" BL!)
Old May 15, 2010 | 10:06 AM
dkk1661's Avatar
dkk1661 is on a distinguished road
The wheel doesn't need to come off, you can still reach it easily. I've read about 10 different ways to get to that plug and the easiest solution i found was to unbolt the steering shaft. But I also have fingers the size of bananas, so it makes it difficult to get my hands in there.
Old May 16, 2010 | 02:23 PM
jlockEMT35's Avatar
jlockEMT35 is on a distinguished road
I use a combination of the above methods. I go in through the wheel well and pop the socket on and use a wrench to break the plug loose and then pop the ratchet on with an exstension and universal joint. Works for me, never tried pulling the steering column but that also sounds easy. I pull the tire but its not necesary, you can just tirn the wheel to get enough room to reach but I'm a short stocky guy so I have some reach issues. If your taller then me (5'6") you should be able to get it without an issue.
Old May 24, 2010 | 12:00 AM
davedidit's Avatar
davedidit is on a distinguished road
I just changed my plugs and used the plug socket and a end wrench
used a short section of fule line to get the new plug started and back to the plug socket and end wrench
take your time and don"t get mad at it it can be done
oh..... yea replace them with platium plugs and you don't need to do it very often
Old Sep 12, 2010 | 07:52 AM
drjoe's Avatar
drjoe is on a distinguished road
Default #3 plug
Just pull the motor mount bold and jack up the engine an inch or two using a wood block on the jack. Don't want to hurt the pan.
Old Sep 12, 2010 | 09:38 AM
Logan's Avatar
Logan is on a distinguished road
Im sooo glad my ZR2 doesnt have this problem. Dont know why, but using the sp socket and an extension works fine for mine. 1/2 max to do all 6 plugs in my ZR2.
Old Sep 13, 2010 | 08:59 AM
R2P's Avatar
R2P
R2P is on a distinguished road
The ZR2 steering column is at a slightly different angle/position and doesn't block the plug like it does on others.
