4 x 4 stuck in 4 Hi
I have a 2001 Blazer 4x4 and put it in 4wd this morning in the snow. When I tried to switch it back to 2wd it wouldn't switch back. Seems to be stuck. Any thoughts???
RE: 4 x 4 stuck in 4 Hi
TRY SETTING THE TIRE PRESSURE CORRECTLY IF THATS NOT IT, YOUR CABLE FROM THE FRONT DIFF TO THE VAC, UNDER NEATH YOUR BATTERY, MAY BE ROTTED... U HAVE A LEAKY BATTERY?
-JIM |
Thanks Grkblazer. I finally got it into 2Hi by putting the shifter in neutral. Then it wouldnt switch back into 4 Hi. So, I disconnected the battery for a few minutes and that worked. Thanks for the info though, because I think I only reset the computer, and probably didn't fix the real problem. I'll check out the other parts and see what caused it...
