5 speed tranny swap 97' 4x4 blazer
Old 04-27-2013, 07:54 PM
latunguley's Avatar
latunguley is on a distinguished road
I like the tune idea. Where does one get that at? As for the dealership downloading from Tech 2? That only cost me 62.50 USD the last time I had that doen for my alarm and RKE? But it sounds like the best option for the 5 speed swap?
Old 05-29-2013, 08:19 PM
roypai's Avatar
roypai is on a distinguished road
there's a way to wire into the harness for the gear selector for the auto transmission - uses i think 3 relays... I made myself a diagram on how to do it i'll see if i can find it or re-do it
basically when you clutch it tells the comp you're in neutral (for starting) and reverse switch on the 5 speed tells the comp reverse (for the lights) and clutch out, not in reverse it tells the comp you're in 'Drive' so there's no rev limiter (user takes care when not actually in gear about revving it)
Let me know if there's interest and I'll exert myself to do a mini write-up on the concept
Old 03-16-2020, 05:33 PM
Caleb Gatz's Avatar
Caleb Gatz is on a distinguished road
Would this be the same case with a 97 S10
Old 03-17-2020, 01:22 PM
You should probably start a new post. This one is pretty old. And your question isn't very clear, since the OP is about a '97.
Pipewrench Dale
11-10-2014 06:16 PM
jdub9000
07-22-2013 07:58 AM
RickBlazer
06-23-2011 04:59 AM
FJackson4904
09-06-2010 09:04 AM
Quick Reply: 5 speed tranny swap 97' 4x4 blazer
