96 4.3 SCFI to MPFI Swap info needed
anyone have a how to on the scfi to mpfi swap?
things like the part numbers would be espically helpful. thanks |
RE: 96 4.3 SCFI to MPFI Swap info needed
I do believe i have posted part numbers before. Are you wanting to do it for performance reasons or to replace a faulty SCFI unit? Cause there will be pretty much no performance difference.
Anyway, here's where I posted the PNs: https://blazerforum.com/fb.asp?m=30138 |
i have a faulty unit in my blazer.
thought it might be the converter causing my bad fuel milage/stumbling/etc but i punched the honey comb outta the cat this past weekend and while the truck now runs better....... its still has the same problems jsut not as severe. |
i thought there was a bracket that needed to be replaced as well...... and also a "nut kit" or am i wrong and do i just need the mpi for my year blazer
If you have the newer SCFI (plastic upper plenum), then all you need is the MPFI spider.
| All times are GMT -5. The time now is 10:35 AM. |
