cam and spider question
Old Nov 12, 2013 | 06:40 AM
bigred01's Avatar
bigred01 is on a distinguished road
Default cam and spider question
I just blew the head gaskets and prob warped the heads so its time to upgrade, I saw they make cams for the 01 4.3 which do you recomend?, I want more fuel to the motor I can't find a bigger spider is their one? I will be milling the heads either the originals or another set I figure .010 is safe( I think I have that right).
Old Nov 12, 2013 | 07:14 PM
Don't go crazy milling the heads. Coolant leaks from the intake gaskets are common on stock engines. The more you shave off the heads, the worse the intake will fit, (intake to cylinder head angles change when you mill the heads). If the intake doesn't fit properly, the crankshaft bore alignment can be tweeked when you torque the intake bolts down. Here's a warning straight from the GM "dealer issue" shop manual:
The stock fuel delivery system is capable of supplying over a quart of fuel in 30 seconds. You'd need some type of forced induction, (blower or turbocharger) to force feed that much fuel into this engine. There are companies that make bolt on kits for the 4.3 engines... $3500+
The poppet nozzle diameter and PCM pulse width are matched to deliver the correct fuel flow. For example: a 3ms pulse width delivers a given amount of fuel: If you open up the nozzle diameter, the PCM will not be able to accurately control the fuel mixture, without reprogramming it. You're better off buying a PCM performance tuner. The manufacturer would need to know the specs on the new camshaft such as lift, duration, overlap, etc. It's possible to squeeze 500+ HP out of these engines, but it has to be done right, and it's not cheap Seems like at least one of our members has a turbo, can't remember who though.
Old Nov 13, 2013 | 06:29 AM
bigred01's Avatar
I think I have to mill the heads or find a new set I drrove it at 260 for 5 miles and it got to 260 three times now. Cam wise I'm just looking for a nice bump up.
hunter05
35
May 16, 2024 09:01 PM
hunter05
Mar 29, 2014 11:32 AM
hubbmatt
Performance & Brainstorming
Nov 11, 2009 01:02 PM
94blazer00
Engine & Internal
Aug 14, 2007 08:51 PM
4thgenssuck
Engine & Internal
Mar 16, 2007 06:46 PM
