electric fans
does anyone know how much of a job mounting THESE would be?
RE: electric fans
Depends on your mechanical skills.
Basically your pulling off the clutch fan, mounting the electrics, and then wiring them in. How long will that take you? Altough before you buy that set-up, do a websearch for Taurus fans. |
RE: electric fans
ORIGINAL: Hanr3 Depends on your mechanical skills. Basically your pulling off the clutch fan, mounting the electrics, and then wiring them in. How long will that take you? Altough before you buy that set-up, do a websearch for Taurus fans. Taurus fans are inexpensive, even the GM 3.8L dual fans can be had for less than $50 at your local wrecking/auto salvage yard. The GM 3.8L fans are identical in function as the LS1/LT1 fans from Camaros, if not the same fans...a buddy of mine got both sets from ebay and we can't tell which is which in CFM and looks. But the LT1 fans have small rectangles where flaps are for highspeed pass through... |
RE: electric fans
Hey, thats great info.
I am kind of a purist at heart. In that I like to install GM parts into my GM vehicles. Anytime I can use a GM version over a Ford version I am all for it. You got any more info on those GM 3.8L fans? Donor vehicles? Specific years? That type of stuff? |
RE: electric fans
Yea hanr any W-car would have these....Impala,lumina,monte carlo,grand-prix,regal from 1988-current. And IIRC the 2000 and newer POLICE PACKAGE Impala has a HEAVY-DUTY version of this fan set-up.
RE: electric fans
Sweet.
That's awesome info. Are they two speeds fans as well? What's a typical wiring schematic for them? |
RE: electric fans
Well HenryJ on S10crewcab site has a how to on the dual fan setup. He used the flex-a-lite adjustable controller for his setup. he has a wiring diagram with the install..
| All times are GMT -5. The time now is 09:00 AM. |
