External oil filter and lines
Does anyone know if they make an adapter for where the external oil lines connect to the engine so that the oild filter can screw on directly to the bottom of the engine.Also I need a pic of the 2 bolts that hold it in place if anyone can show me what they look like.Thanks
1 Attachment(s)
Here is the bolts that hold the oil filter onto the core support if thats what you wanted.
Attachment 32583 And what year jimmy do you have?? If its newer then you have a oil cooler and you would have to bypass it. Why do you want to do this?? |
from checking his other posts he has a 96.
97 Cherry can you take a pic of the bolts that hold the external adapter to the engine.Also to answer your question I did not know that setup had an external oil cooler so I guess I will leave that alone.Thanks for the info.:)
You can use the plate off a 350 to have your oil filter on the side of the block but if its 4 wheel there ain't enough room cause you Will need a ph5 filter
I have had this project taken apart for so long that I had forgot the lines go into the radiator.Anyways I was able to reconnect everything back together the right way.
