Fuel Pump Or Filter?
Old Sep 9, 2006 | 01:33 AM
99kickerblazer's Avatar
99kickerblazer is an unknown quantity at this point
Default Fuel Pump Or Filter?
i drive a 1999 chevy blazer. recently my truck has been trying to start but wont. the first time it happened i had to push the throttle manually from the engine bay. right away it started. within three days i went to start it, buyt it wouldnt start. i checked the throttle body and gas doesnt come out when i try to start it. its been three days and havent been able to start. one guy told me the it might be the throttle body positioning sensor, but im begining to think it might be the fuel filter or worse the fuel pump . can anyone help me??
Old Sep 9, 2006 | 03:59 AM
Hanr3's Avatar
Default RE: Fuel Pump Or Filter?
Do you hear the fuel pump come on when you turn the key to run? It should come on for 2 seconds and stop.
Old Sep 9, 2006 | 01:02 PM
yeah it whines a little then it turns off
Old Sep 9, 2006 | 02:10 PM
Gutmann795's Avatar
Gutmann795 is an unknown quantity at this point
I just changed my fuel filter on my 98 blazer. My roommate said i should get it done cause i haven't had a tune-up yet and I still have a lot of the original parts on my truck. 95K+ miles. Im not sure how much I can help, but I figured I would offer my advice.
.. out of curiosuty?
have you had a tune-up yet?
how many miles on it?
Old Sep 9, 2006 | 03:28 PM
not really all i did was oil changes and ****. but not a tune up, and ma truck got 150k on it.
Old Sep 9, 2006 | 03:44 PM
1996BZR's Avatar
1996BZR is an unknown quantity at this point
I don't think it would be the fuel pump since you heard it whine...I'd try the fuel filter first, then see what happens.
Old Sep 9, 2006 | 04:48 PM
kool. thanx. i will be changing the filter soon. but wat if once i put it in and nothing happens? any idea wat i could be?
Old Sep 10, 2006 | 04:09 PM
ok. i changed the fuel filter, but the car wont start. the pump works good and everything. but i cant get the truck to start. can anyone help
Old Sep 10, 2006 | 11:22 PM
Hanr3's Avatar
Did you put a fuel pressure guage on it to see if it really is pushing the proper fuel pressure to start the truck. Should be around 54-60psi. Verify those numbers before you test it. Lets say those are the right numbers, and your only pushing 50psi, it wont start, but it will run once its going. Sound familiar.
Plus spark plug gap widens over time. If your plug gap is too big, it wont start. Plus there are a whole host of other things that could be wrong. Since you have 150,000 miles on her, I highly recommend a tune up before you spend money on anything else.
Old Sep 11, 2006 | 02:53 AM
1996BZR's Avatar
yea, you might try pouring a little gas down the throttle body while turning it over. If it fires up, but doesn't stay running long, you can say it definately has something to do with the fuel...maybe the injectors are clogged.
