-   Engine & Internal (https://blazerforum.com/forum/engine-internal-9/)
-   -   Help please identify the type of sensor (https://blazerforum.com/forum/engine-internal-9/help-please-identify-type-sensor-49149/)
Vladimir Sep 15, 2010 01:54 AM
Help please identify the type of sensor AFS 105 Delco Heated Oxygen Sensor - titanium ? zirconium ?
And where to see the scheme ?
R2P Sep 15, 2010 05:13 AM
Dunno if it's titanium or zirconium.
By scheme I assume you mean what each wire does?
Black-------Sensor Output (Signal to MS)
Gray--------Sensor Ground (tie to MS Gnd)
White--------Heater (Ignition switched +12)
White--------Heater (Gnd)
Vladimir Sep 15, 2010 06:13 AM
Thank you very much for the scheme. I put the system of fuel economy on the water. Need to know how to connect the control unit and need to know what type of sensor - zirconium or titanium
R2P Sep 15, 2010 06:25 AM
The AFS105 will work, it comes stock.
rriddle3 Sep 15, 2010 06:55 AM
*Vladimir, I have deleted your other 4 threads asking this same question. Please read the Forum Rules and you will see that double posting the same question in multiple sections may result in loss of posting privileges.*
