Low gas milage?!?
hey everyone, for some reason, im getting really low milage on my 1995 blazer (11.4 miles per gallon). Anyone know what might be the cause of my problem? thanks in advance
-infamous |
RE: Low gas milage?!?
Could be a lot of things. Air Filter, plugs, wires, cap and rotor may need to be replaced. Could be inproper tire preasure. I would try the easy ones first. Also if its cold out and you let it warm up longer that could also be part of it. All winter I was getting 14 mpg consitintly now that it started warming up Im getting 16 consitently and have gotten as good at 19.
i installed a remote start( part of my alarm system) it is awsome on those cold winter days:D
Mine started getting 15 mph when I was used to around 20, so I took it in to the shop and it ended up being blown fuel injectors. Once those were replaced I got back up to 20+mpg. Its a possibility, though my check engine light was on when it happened.
