-   Engine & Internal (https://blazerforum.com/forum/engine-internal-9/)
-   -   My POS Blazer Won't Turn Over in the Rain (https://blazerforum.com/forum/engine-internal-9/my-pos-blazer-wont-turn-over-rain-3606/)
PawNtheSandman 05-17-2006 03:09 PM
My 98 POS Blazer:
This week's problem:
Car won't start.
Battery is new, plugs, wires are all new.
Car has power, but doesn't turn over.
You hear it try to start, but never fully turns at the end.
Won't start in the rain or after it rained.
What could be the problem? Starter? Wires??
hillbillyinOhio 05-17-2006 04:03 PM
RE: My POS Blazer Won't Turn Over
could be the battery cables, I had a bad ground on mine and it wouldn't start, just make sure the cables are tight, and make sure that the plastic on the terminal end isn't stopping you from getting good connections. I just cut mine off.
MCas86 05-17-2006 05:25 PM
this was happening to my buddies jetta...there was just corrosion on the terminals...take a wire brush to it and see if itll start, then let us know how it went
PawNtheSandman 05-17-2006 06:10 PM
battery is new.
Terminals are clean, make contact.
MCas86 05-17-2006 06:12 PM
possibly the starter?
jagblazer01 05-17-2006 07:45 PM
ORIGINAL: MCas86
^^thats a good possibility, also im not sure but maybe check the alternator. again im not positive on that
1996BZR 05-17-2006 09:30 PM
probably the starter. I don't think the alternator would make it not turn over unless the alternator didn't charge the battery, causing the battery to run out of juice.
MCas86 05-18-2006 02:18 AM
yea it cant be the alternator because he said its a new battery, in which case the alternator hasnt even had a chance to try to charge it...seein how its never been started with it..anyways, id say its the starter
VRDriver4l 05-25-2006 02:10 PM
Id say starter also, the best alternator test is when the car is running disconect the battery if it stays running the alternator is good if it shuts of go to the part store and get a alternator, im sure most people know that though.
Dory 05-25-2006 04:42 PM
Ok I dont say starter... all you need to start the car... power, spark and FUEL. ARE YOU GETTING FUEL??? If not, FUEL PUMP. ;)
Thats my thought... if it cranks fine and no fuel... well, thats just my thought.
