Nice 4.3 engine build set-up
Old Sep 2, 2012 | 10:43 PM
LIFTED-JIMMY's Avatar
LIFTED-JIMMY is on a distinguished road
Default Nice 4.3 engine build set-up
I am building up my 4.3 vortec out of my 98 jimmy 4x4 .
tell me your opinions and if you think it will be a good or bad combination
i personally think it will be perfect for a daily driver
block bored 0.40" over
flat top pistons
crane cam #1439811 (.429 lift )
machined & ported heads
1.5 ratio roller rockers
hedman shorty headers
im thinking this combo will run nice and will bring it up from 190hp stock to around 230-250hp ? any comments?
Old Sep 4, 2012 | 12:24 PM
skotti's Avatar
skotti will become famous soon enough
V8!
the cost involved into getting to the numbers 230-250, is not worth it. I dont think what you listed would get you there.
Drop a v8 stock at 255. done.
Old Sep 4, 2012 | 12:36 PM
chris015's Avatar
I agree. You can tag a running v8 for +/- $500 locally if you know how to find them. Do either a simple carb setup or switch wire harnesses and computers and go! for about a grand you can have a v8 swap that'll turn heads.
Old Sep 4, 2012 | 05:21 PM
Jeff Hoard's Avatar
Jeff Hoard is on a distinguished road
https://blazerforum.com/forum/builds...jection-73518/ look at this i have done a lot of reasearch and searching to find the parts but it will be a mean build and its not too ridiculously expensive. also when u do that u have to have ur heads done which inclueds screw in studs and bigger valve springs to make ur vavle close and forgot to put it in there
Old Dec 27, 2012 | 11:25 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
flat top pistons
I think it will get you close to 230hp especialy if you use performance chip and use a higher lift cam..
Im also considering rebuilding a 4.3 with flat tops and bigger cam. Im either staying with tb injection or cpi since I have a new seup for it.New injectors,fuel pressure regulator.Im also going to have the heads ported and polished.
Blaze1Chef
Mar 7, 2021 10:44 AM
speeddemon560
Feb 10, 2007 12:55 AM
zero psi
Feb 10, 2006 03:55 PM
BlazerChick
Nov 7, 2005 10:52 PM
