Push Rod's ??
Im just now putting all the push rods back in, and I am having trouble, The book says to have them Torqued Down to 45 well I did just that and the engine won't turn over at all ??? So should I just loosen em all up until the engine turns over or would it be fine to leave em like that, But I figure you would have to have the engine turn over in order for them to be correct..
RE: Push Rod's ??
If you would be so kind as to let us know what it is you are working on here...
And you are torquing down the rocker arms? And to 45 ftlbs or inlbs or what? My references state to torque the rocker arms to 22 ftlbs. But overtorquing the rocker arms should not lock up the engine... These are not adjustable rockers, but net lash rockers... |
RE: Push Rod's ??
oH im sorry, its a 2.8, 1986.. Well I put a lil oil in there and that allowed it to spin freely.. AND yes I am torquing down the Rocker Arms..
RE: Push Rod's ??
Ok, that makes a big difference then. I think that these rockers are adjustable (do they have a seat under them?). If they are adjustable, then there isn't a torque value that you use. You roll the motor over until you are on the smaller profile of the cam with a particular valve, then you tighten down the rocker arm until the rocker arm hits the valve stem and stiffens up. Then its something like 1.5 turns down after that to set the proper hydraulic lifter preload.
| All times are GMT -5. The time now is 10:05 AM. |
