Questions about updating a 1990/91 K5
Don't know where to start so I'll start somewhere :)
With a 1990/91 would you rebuild the engine, upgrade with aftermarket heads, add newer auto-tune EFI or Look for something like a ~98 or so donor truck and get the newer 4l60e and Vortec heads and rebuild all of that? Or other suggestions. My odd thought was a 4.3 with turbo... |
Intended use is missing from your question. What is your goal? Budget? Condition of your existing engine and trans? Vortec heads will bolt onto your 90/91 block but you must use a vortec intake. Are you doing the work yourself or paying someone?
"Should I rebuild my motor and trans or get another used one?" Without any more details is impossible to answer intelligently. |
Best bet would be to swap an LSX and 4L80E tranny, regardless of what you want to do with it. Better power, economy and emissions. Otherwise, nothing wrong with building up what you have. Pretty easy to get 300 hp out of what you have but you'll suffer on mpgs.
I stand corrected. Thanks AJ for the intelligent answer.
Originally Posted by Rusty Nuts
(Post 679055)
"Should I rebuild my motor and trans or get another used one?" Without any more details is impossible to answer intelligently. Budget friendly is nice but I don't want to be pound foolish, penny wise either. The next question is when do I pay someone else to do (any machining certainly). I can do general work. The biggest things I have done is change master cylinders, rebuild calipers, change bushings out of steering components etc... |
Originally Posted by AJBert
(Post 679056)
