-   Engine & Internal (https://blazerforum.com/forum/engine-internal-9/)
-   -   quick question... quick answer (https://blazerforum.com/forum/engine-internal-9/quick-question-quick-answer-7961/)
blazinwoody Jan 11, 2007 04:52 PM
Trust me... I don't like starting posts before I search it first but I still need help
I got the code P1870
"Tranmission automatic 4-wheel drive indicator (lamp) circuit short to battery."
"Tranmission mechanical transfer case 4x4 switch circuit short to battery"
From doing a search I've read it's the control valve body.... my question is... Is is still safe for me to drive it home (interstate for about 55min.) this weekend or should I try and fix it. Last thing I want to do is buy a new tranmission right now.
Can I drive it is or should it be replaced asap?
Thanks
sledneck16 Jan 11, 2007 05:30 PM
RE: quick question... quick answer
as long as it isnt switching in and out of 4x4 then you'll be fine if you keep it in 2wd---but get it fixed as soon as practical because that damn check engine light is annoying as crap! [8D]
