Seafoam????
Ok I saw a post about this stuff awhile ago Uh help me lol. Where do i get some and how do i use it?
I couldnt find it in a search or im just stupid :D Thanks ;) |
RE: Seafoam????
1. With engine warm, slowly pour 1/3 to 1/2 pint through throttle body throat. Turn ignition off. Restart engine after 5 minutes. If severe carbon build up is apparent, then do it again. Various ways as fumes will be extreme for a short time.
2. Pour 1/3 to 1/2 pint into oil crank case to clean rings, lifters, dirty parts and remove moisture. 3. Pour 1/3 to 1 full pint into fuel tank to clean injectors, carburetor jets, fuel lines and remove moisture. Immediate Results: Smoother idle, increased R.P.M.'s better throttle response and improved performance. See label on can for detailed results for use in each area. You can get it at Napa, O'Reileys, Advance Auto Parts, Pepboys...yea http://www.seafoamsales.com/motorTuneUpTechGas.htm |
RE: Seafoam????
Well any well supplied Autoparts store should have it. Not knowing what part of the country you live in suggestions will be of a National companies that I know of. NAPA Autoparts has it but charges 1-2 dollars more than a partsamerica.com related store would. I purchase mine at Schucks, I believe that they are part of a national chain of stores that use the partsamerica.com web site as there internet purchasing site.
Other than that I am out of suggestions as to where to get it. They also have a website that you can read about all there products on... http://www.seafoamsales.com/ |
