-   Engine & Internal (https://blazerforum.com/forum/engine-internal-9/)
-   -   Slave cylinder (https://blazerforum.com/forum/engine-internal-9/slave-cylinder-8716/)
twintrades Feb 12, 2007 10:30 PM
Slave cylinder
Ok When i push down on the clutch i cant engage it. But if i lighty push a couple of times them push all the way down it will work some times. Could that be air in the line?????
4lowlife Feb 13, 2007 01:23 AM
RE: Slave cylinder
I would try bleeding it first.
Is there a whirring noise when you depress and hold the clutch? If so, that's your throwout bushing/ bearing worn out.
twintrades Feb 13, 2007 05:26 PM
RE: Slave cylinder
I tried Taking off the slave and letting the bleeder out then pushing the plunger back in by hand. Then tighting it I think i just need to get some more air out that way. It just to cold ill wait till this weekend.
4lowlife Feb 13, 2007 05:29 PM
RE: Slave cylinder
have someone push the clutch pedal a few pumps fully to the floor at least 3 times while its bleeding.
