-   Engine & Internal (https://blazerforum.com/forum/engine-internal-9/)
-   -   supercharger for old blazer (https://blazerforum.com/forum/engine-internal-9/supercharger-old-blazer-2300/)
psyco1887 Feb 6, 2006 06:46 AM
i have a 1992 and a 1994 s-10 blazer 4.3 engine. the 94 is a vortec and the 92 is the regular 4.3
and i can't find a supercharger or a turbocharcher for either.
i figured i could take one off a typhoon but i can't find one of them either.
anyone know a place?
Bgray Feb 7, 2006 12:14 AM
RE: supercharger for old blazer
Whipple use to make a huffer for the TBI 4.3...try them
swartlkk Feb 7, 2006 12:49 AM
Pretty much anything forced induction would have to be custom. The easiest course would be to get a procharger (Centrifugal S/C) and just have custom mounting plates made up (or possibly use a mounting kit for a 350sb), but you'd need to go with their smallest unit and then you'd probably have to put on a larger pulley to make it turn slower due to the lower displacement.
The problem with both a turbo or CSC is that the bottom end should really be upgraded. At the very least, some 8.5:1 pistons should be tossed in to keep from getting very harmful detonation due to excessive pre-ignition cylinder temps. High temps can be over come with an intercooler for both cases, but the CSC may be able to run without an intercooler with lower compression pistons. The CSC would require less custom fab than the turbo (collector pipes, down tubes, intake piping, intercooler piping, etc).
Either option is a daunting task to say the least! Good luck!
20Blazer00 Feb 7, 2006 03:20 AM
psyco1887:
Try Race Proven Motors at http://www.raceprovenmotors.com/inde...10ccd8b5e3ad10
The deal in Cyclone/Typhoon parts and machine work...
Maybe also try http://www.syty.net/forums//index.php?
psyco1887 Feb 8, 2006 04:01 AM
i was already planning on upgrading to forged pistons.
but i am also having a little bit of trouble finding a vendor for the pistons too.
i can only find parts for imports.
and all the domestic websites i have seen have been in sets of 8 only.
RedBlaze Feb 8, 2006 06:11 PM
Is the 94 a CPI?? if so they do not make any supercharges or turbocharges for that motor
psyco1887 Feb 9, 2006 03:14 AM
the 94 is a central multi port fuel injected vortec
RedBlaze Feb 9, 2006 01:09 PM
Yeah I used to have one of those motors myself. They do not make a supercharger or turbocharger for that motor.
