-   Engine & Internal (https://blazerforum.com/forum/engine-internal-9/)
-   -   weak startup (https://blazerforum.com/forum/engine-internal-9/weak-startup-6051/)
blazinloud 10-16-2006 04:38 PM
weak startup
sometimes when i startup it kinda starts weak, then surges and dosent sound very strong. happens maybe 50% of the time......would this be mainly my batteries fault? Or is there more to it such as fuel pressure or something.......?
Adam
swartlkk 10-16-2006 05:09 PM
RE: weak startup
I do not think that fuel pressure would not have an impact on the starting power of your vehicle. This is typically caused by a loose/corroded connection to the battery. A dying battery could also be the source of the problem as well as possibly a dying starter. The reason why I stated the battery connections first is because it is intermittent. A loose or corroded connection will vary with temperature, humidity, etc...
Does it do this more when the engine is hot or cold? Anything else that accompanies this behavior that may help us diagnose it further?
blazinloud 10-17-2006 02:43 AM
RE: weak startup
on cold startups it starts very good and strong.........I will check the connections, but im sure there nice and clean, and probably not loose....cant think of anything else that goes to it......
and thanks for the reply kyle, ur toooooooo deadly, lol.
4lowlife 10-17-2006 01:06 PM
RE: weak startup
Your alternator may be going.
Get the alt, starter, and batt to A-zone for a free diagnostic.
blazinloud 10-17-2006 04:50 PM
RE: weak startup
alt and batt are brand new!!!!! i hope not.......maybe my stereo drains too much of the batt. juice. No autozone here......think its 25 or 30 bucks to get that checked....
ahhh well, my alt is still warrentied....anyway to check a starter? and how much is a new one? could it be the 'ignition control' thingy or no......my mechanic said they commonly go bad......or something to that effect :D
guywm25 10-17-2006 05:21 PM
RE: weak startup
If after checking the battery connections the battery itself and that is not the problem, just a suggestion, when I bought my alternator at the local parts store, the "old man" behind the counter reminded me to make sure and clean the ground wire connected to the chassis, like I said it is just a suggestion.
blazinloud 10-17-2006 05:39 PM
RE: weak startup
thanks guy :D
My mechanic just slapped er in, I needed my truck back fast.....took em about 10 or 15 mins........
