00 blazer won't pick up and go
Old Jun 27, 2012 | 07:07 PM
Ferrante33's Avatar
Ferrante33 is on a distinguished road
Default 00 blazer won't pick up and go
Hello I have a 00 blazer lt 4x4 it has one code secondary air I was wondering if that had anything to do with the pick up if it doesn't what will I replaced spark plugs wires d cap fuel filter and air filter and it still doesn't run like it should
Old Jun 27, 2012 | 07:17 PM
50lb_cat's Avatar
Have you tried to clean the MAF sensor? Some one please correct me if I'm wrong but I don't think the secondary air system will have a negative impact on performance.
Old Jun 27, 2012 | 09:12 PM
NewbieT's Avatar
NewbieT is on a distinguished road
The AIR system, or air injection, is used for emissions. It re-starts the burn to burn the HC and heat up the cat at cold start up mostly. No negative impact on driveability. Like 50lb cat said start with cleaning the MAF, don't touch the resistor's directly. If that doesn't help I would check 02 sensor output, idk if there narrow or wide band on the pre-cat. Should be dithering below 100mv and above 900mv for a healthy sensor. Next I would check fuel pressure KOEO, then key off and it should maintain pressure for a few minutes. GL!
Old Jul 12, 2012 | 02:05 PM
Ferrante33's Avatar
I heard that it could be a fuel pump or intake gasket I just don't understand why when it's cold it almost want to stall but never does but when it warms up a little it run better but still not what it should have anyone? Answers! Plz
Old Jul 12, 2012 | 02:50 PM
50lb_cat's Avatar
Try unplugging the MAF sensor. If it runs better then you need to clean the wires inside the maf with some maf sensor spray cleaner. Don't touch the wires!
Old Jul 12, 2012 | 05:46 PM
Ferrante33's Avatar
I tried that that work I have a 4x4 problem also it will work in 4 but soon as u drive a mile the service engine light on and my blazer stuck on heat when I turn it to 65 its still super Hot it has that smart cilmate control
konfettix13
Tires and Wheels
Oct 12, 2013 08:34 PM
burning_soul07
Feb 7, 2011 08:54 PM
bigdaddykane93
Dec 6, 2009 05:28 PM
rogggg1020
Oct 25, 2008 11:10 AM
