00 Fuel pump issues [no surprise]
first one i installed worked awesome, 3 years later pump still working and then just whenever i would get out and get like food, Then come back to start it up , it wouldn't hold pressure and just stall i would have to cycle the key 2 times in order for it to fire up, so i got ticked off and replaced it and the wiring to see if i could get my gauge working for fuel, so i did, i was so excited cause my fuel gauge WORKED!, then the next day it primes. no start tho i tested everything, took the plugs out , cleaned them , tested every fuse , tested every spark plug wire, , Coil's everything checked out perfect, just the only thing i could think of was either a bad pump or bad fuel, so tomorrow I'm going to a local parts store and going to bend over and pay for a proper fuel pump and not a Chinese pump from ebay
