-   -   1 or 2 pc bell...witch do i have? (https://blazerforum.com/forum/engine-transmission-35/1-2-pc-bell-witch-do-i-have-23269/)
amp88fan 09-15-2008 10:57 AM
i have a 95 blazer 4x4...4.3 vortec, the trans went bad and now im lookin to buy a used one..found a great deal on a 4L60E with less than 80k on it...heres the kicker...it is a1 piece bell housing...do i have a 1 or 2 piece bell?...i am a big dude so i cant get under her very far without gettin it up on ramps or stands but from what i could see it has a larger than im used to seein dust cover with 2 bolts in each side and 2 support braces running from the engine to the dust cover with bolts in each one...
swartlkk 09-15-2008 07:08 PM
RE: 1 or 2 pc bell...witch do i have?
You have a single piece main transmission case.
myol blue4x4 09-15-2008 07:14 PM
Wouldnt it have a seperate bellhousing that can come off if it was a manual tranny?
swartlkk 09-15-2008 07:17 PM
If it were a manual transmission, then yes. Since he is looking at installing an automatic...
amp88fan 09-15-2008 07:38 PM
first of all...thanks for all the help already...i've spent about the last 10 or so hours pouring over these forums and learned a hell of a lot in doin so....now if it is a single pc bell then this trans will work fine then right?......http://cincinnati.craigslist.org/pts/815745894.html
myol blue4x4 09-15-2008 07:59 PM
Yeah that looks like the one you need.
amp88fan 09-20-2008 11:23 AM
can someone ...or does anyone have any pics of a 1 pc and 2 pc ...i want to make sure this is the right trans i need....see link in post above....
Hanr3 09-20-2008 06:42 PM
2 piece
http://chevytruckworld.tenmagazines....nr2/211433.jpg
http://chevytruckworld.tenmagazines....nr2/211434.jpg
the link you posted above is a 1 piece and hte one you want if you ahve an auto tranny and have 4x4.
amp88fan 09-20-2008 07:52 PM
ORIGINAL: Hanr3
2 piece
hey thanks a ton man!!...i have read a lot of the write ups you have done here and on chevytruckworld.com....ive even printed most of them out.....very informitive...thanks again....
Hanr3 09-21-2008 10:48 AM
Your welcome and thanks for the kudo's.[sm=icon_cheers.gif]
