-   -   100K Miles Tune-up (https://blazerforum.com/forum/engine-transmission-35/100k-miles-tune-up-26658/)
tmurph01 01-17-2009 04:16 PM
100K Miles Tune-up
My Jimmy is getting close to hitting the 100K Mile mark. What kind of maintenance, if any,should be done?
Jimmy is a 2001 4-door, 4 wheel drive
Thanks guys!
NVANZEE 01-17-2009 06:43 PM
RE: 100K Miles Tune-up
i also would like to know. anything besides plugs, wires, fuel filter, air filter, oil change, coolant flush?
rriddle3 01-17-2009 07:07 PM
Go to this site, register your VIN, and you can download a pdf of the owner's manual with recommended maintenanceschedules in it.
swartlkk 01-17-2009 07:52 PM
Maybe check out the related threads below as well.
Jazon 01-17-2009 10:20 PM
You may also want to consider checking all of your sensors.
c5ce 01-17-2009 11:40 PM
I'm planning on a tune up this spring. Plugs, wires, cap, etc. I'll use AC/Delcoirridium plugs. They are recommended for LSx engines, so they should do the trick well in a 4.3L.
I use GM parts, usually GM Performance parts, and I buy from GM Parts House at http://www.gmpartshouse.com
I use sythetic oil and change every 5k miles. I also change the air filter at every oil change.
Hanr3 01-19-2009 12:07 PM
Replace your vacuum hoses, especially if they turn your hands black when you touch them.
