-   -   1200-1800 rpm vibration (https://blazerforum.com/forum/engine-transmission-35/1200-1800-rpm-vibration-83684/)
guitar134 01-05-2014 03:45 PM
Noticed when at the above listed rpm's the motor seems to vibrate the truck pretty good. not misfire bad, but enough to wiggle the seat. its on a fresh tune up, and distributor, runs fine otherwise.
ideas on places to look?
rockp2 01-05-2014 04:05 PM
Did you check your motor mounts?
guitar134 01-05-2014 04:49 PM
i didnt suspect mounts because while under the hood, revving the motor it doesnt move excessively, i will double check them tomorrow on the lift while im doing some other work though
rockp2 01-05-2014 04:56 PM
If the mounts have never been replaced, there is a good chance at least one of them is bad. This is common. If it does end up to be the mounts, somewhere on here there is a link to some after-market mounts that are not only more durable, but of a better design for installing. Also, give yourself plenty of time to change them because Blazer mounts are the hardest to change I have ever experienced (though I am only a "shade tree" mechanic").
Diaita 01-05-2014 10:58 PM
Is it only when the engine is under load, or all the time?
guitar134 01-06-2014 06:45 PM
i notice it most when im revving it to warm it up, or at low speeds
01-06-2014 07:00 PM
Sorry new to this, first Ford or Chevy?
Year, Make and Model.
"not misfire bad" What the heck does that mean ( more info please ).
New problem or old problem.
Diaita 01-07-2014 12:27 PM
A spark plug wire not installed correctly? Spark plug with a cracked insulator? Cap/rotor not installed properly?
