-   -   1986 Blazer won't shift out of 1st (https://blazerforum.com/forum/engine-transmission-35/1986-blazer-wont-shift-out-1st-20817/)
lpaz 05-18-2008 05:55 PM
I have a 986 Chevy Blazer with a 305 and I think the 700-4 transission? I know it is a 4 speed or overdrive trans, at any rate.
I recently got this running again, after it had sat for awhile, and now it is not shifting out of 1st gear.
I can get up to 25mph or a little over, and it just stays in 1st gear.
Is there some sort of vacuum line or a switch on these that could cause this, or I am just looking
at a having to do a tranny rebuild?
The reason it sat for awhile is because I left it at a storage site, and the carb got stolen, along with a hole punched in the gas tank.
So I had to get some things fixed before I could run it again, but now I would like to get it running, if I can.
I checked the trans fluid, and it looks a little brown, and it was a little low, but I have added trans fluid, and it still doesn't shift out of 1st gear.
Thanks for the help!!!
WolfPack 05-18-2008 06:01 PM
RE: 1986 Blazer won't shift out of 1st
Brown fluid = not good.
Maybe try dropping the pan and checking the fluid and filter that comes out. If you see any metal/silver spec, you're fubared.
94Jimmy4door 06-05-2008 12:36 AM
You might want to check your vacumm lines to. They may have broke. Check the shifter link on the trans it may have come loose or some thing. [sm=WTFsgign.gif]
