1991 Blazer tranny problem
Old Oct 24, 2008 | 09:20 AM
mcsuper's Avatar
mcsuper is an unknown quantity at this point
Default 1991 Blazer tranny problem
1991 blazer auto trans. I have to give a lot of throttle to get it going (almost like trying to start in higher gear on a manual) Once it's going, it doesn't shift into 2nd until very high RPM. When it does shift, it's a very "hard" shift. Once in 2nd, same thing going into 3rd. Same with reverse - Have to give a lot of throttle to get it to move.
I checked the fluid and it was low. Added fluid to proper level and it still does the same thing. Any suggestions?
Old Nov 12, 2008 | 09:03 PM
CoolAirVw's Avatar
CoolAirVw is an unknown quantity at this point
Default RE: 1991 Blazer tranny problem
That dont sound good. Check the fluid first, but you may need a trans.
Old Nov 12, 2008 | 10:43 PM
mcsuper's Avatar
The transmission was a bit low on fluid.
I topped it off and still had the same problems.
At the suggestion of a friend, I replaced the filter and it still done the same thing.
It then started leaking real bad from somewhere around where it connects to the engine. After talking to 3 different mechanics, they all recommended a new trans. I'm not going to put that kind of money in a vehicle this old with 165,000 miles.
I plan on just selling the vehicle as is. Maybe someone will want it.
Thanks for your reply.
Old Nov 13, 2008 | 05:21 AM
Blue95Blazer's Avatar
Blue95Blazer is an unknown quantity at this point
hey if you decide to sell What kinda shape is the body in and where r you located
Old Nov 13, 2008 | 09:53 AM
Duntov's Avatar
Banned
Duntov is an unknown quantity at this point
That is a common problem with someolder cars. No ownerwants to spend $1600 on a car that is not worth $1000. You can seldom get your investment back in a old car unless it is a model that is in high demand....a 1991 S10 Blazer ain't.
I have the similarissue with my 1991 S10 Blazer SUV, 4WD with 4WAL brakes. I am in the process of replacing theABS modulator valve assembly(EHCU) which cost $700 for a rebuilt unit, and then I must try to find someone that has the ability and knowledgeto bleed that crazy system. Two Chevrolet dealerships told me they don't know how to bleed that system or at least they claim they don't and don't want to be bothered with that kind of work when they have enough warranty work to keep them busy. That is calleda repair shop "bums rush" or "take it somewhere else".
Many auto repair shops will demanda 50% advancepayment on an old car before repairs begin. That is because the repair shops areafraid when the owner gets their bill, he may tell them to stick it. Then the repairshop will be stuck with a car they cannot even sell for salvage and they even would have to pay salvage yard to come pick it up.
Old Nov 13, 2008 | 10:50 AM
mcsuper's Avatar
That's the same as my Blazer. 1991 4WD 4.3L.
And what you are saying is exactly what I found out. I did find a few shops that would rebuild the tranny, and 2 even said the same thing as you-that the tranny would cost more than the vehicle is worth.
Oh, well. It was a good vehicle while it lasted.
Old Nov 13, 2008 | 12:11 PM
Duntov's Avatar
Banned
I have an associate who is a auto repairmanat a local Chevrolet dealership.He furnishes his own tools and equipment and "leases" a stall in the Chevrolet dealership. Heworks on a commission basis just likethe other auto repairmen. Autorepairmenmerely rent a space in a repair shop and are paid a percentage of the bill. The auto repair shops and car dealerships will only pay the repairman a flat rateprice for a job.Therefore the more parts the repairman can use and how fast he can do a job will determine how much money the repairman can make.That type pay schedule is an incentive for the repaiman toinstall unnecessary parts and do fast and incompletework.
I purchaseda rebuiltEHCU for $700 and my friend at the Chevy dealershipsaid he would will put it on and bleed the ABS brakes.I am fortunate to have a friend that is arepairman in a Chevrolet dealership that is willing to do that. I wonder if the dealership knows what he does for some of his friends? He has done thatfor me before andhas done that kind of work for someone else I know. I am sure the dealershipwould beirritatedif they found out what he is doing. He told me they know it and don't care.
If I had to buy the rebuilt EHCU (Electro-Hydraulic Control Unit)from theChevrolet dealership in order to get him to install it and bleed the brakes, I would have to pay $1500 for the unit!
Two independent auto shops and oneChevrolet dealership have tried to bleed theABS brakes but none of their so called "ASE Certified" mechanicsis willing to do it because its take longer than the independent auto repair shop or car dealership will pay. One of the independent repair shops charged me the regular $90 flat rate in their attempt to bleed the brakes after working on them for four hours which resulted in total failure.Another independent auto repair shop and the Chevrolet dealership tried to bleed them andthey failed miserablybutthey did not charge me anything.
I can install the EHCUbut thehard-headed repairmen will not let me tell them how to bleed the ABS system. I gave the goofy mechanicsa copy of Cadone's instructions on how to bleed the '91 S10 Blazer ABS brakes and they refused to read it and tossed it in the trash. They do not want to be told how to do their job by the customer. I am notequipped andin too bad healthto bleed the brakes.
It is nearly impossible to find a shop repairman that can read well enough tointerpret instructions. Most of thos grease monkeys only know how to "put part on" and "take parts off".. All the good shop repairmen are either shop owners or service managers with their feet kicked up on a desk.
Old Nov 13, 2008 | 03:32 PM
Hanr3's Avatar
You can pick up a used tranny for about $500 and install it yourself.
Where do you live. If it's close enough I'll give you $50 for the truck.
Old Dec 6, 2008 | 04:14 PM
aceman2049's Avatar
aceman2049 is an unknown quantity at this point
Ive got a 91 s10 blazer and have the same problem but not the reverse problem. also the lucas transmision fluid might help and that marvel mystery oil I heard might work
h84gotten
15
Aug 27, 2012 01:51 PM
Van
Jun 22, 2012 09:28 AM
aztcwrior25otvws25
May 23, 2011 08:16 PM
K5joker
Oct 18, 2009 06:55 PM
Flapjack
Jan 16, 2007 10:35 AM
