-   -   1991 Full Size AT problem (https://blazerforum.com/forum/engine-transmission-35/1991-full-size-problem-11953/)
fpage 07-22-2007 11:49 AM
I believe AT is going out in my 1991 Full Size Blazer. I am considerind buying a vehicle with a good transmission and switching it out. What should I look for?
Chevy Lover 07-23-2007 12:43 AM
RE: 1991 Full Size AT problem
I'd look for a vehicle with the same options as you have, V8, 2WD, 4WD, 700R4 trans?
Unless you can drive the donor vehicle how will you know the condition of the transmission.
I had a 700R4 rebuilt for $1,000.
I can fix a lot of things, but I don't do automatic transmissions.
fpage 07-23-2007 09:35 AM
Rebuilding may be my best bet...I would have to trust someone that an used trans is OK. I am not sure if it is a 700R4. Thanks!
