1993 gmc jimmy spider injectors all spraying during fuel pump prime
I've been trying to fix this for so long now. I recently"thought" problem was fixed because my acceleration came back and overall the 4.3l V6 finally drove how it should. Then when trying to start it died, then started and died, smell of gas so I knew what to look at. Brought it home took off intake and remove spider assembly. Bought a new fuel pressure regulator and thoroughly cleaned injectors and unit itself. Replaced all gaskets and O rings. Went to start it and kept cranking then noticed fuel smell... Then looked underneath and fuel leaking. Great. Took off plenum again and put power to fuel pump test line and noticed all injectors are spraying when fuel pump is primed. This never happened before. Usually when primed it's the sound of fuel pump and then quiet. Now I hear fuel spraying into cylinders. Is there any way to fix this or are they "toast"? Any info I'd greatly appreciate it. This is my first post I apologize in advance if I'm not posting this properly. Thank you
I can't help with this particular problem, but since you have the plenum off, you might consider changing out the tubes that connect the injector assembly to the rear end of the intake. I had a 92 and one of them cracked spilling fuel everywhere.
As for your issue, could there have been some problem with the injectors that came about from the cleaning? Perhaps you should replace them too. BTW, I hate just throwing parts at problem but it seems like this would be appropriate to try here.
Yes. From my understanding the fuel pressure is what opens up the injectors. I'm not sure what that wiring harness even does.
I'm going to swap out another fuel pressure regulator maybe the new one is defective?
That harness goes to the "fuel injector" that actually meters the fuel. If it doesn't get an electrical signal, no fuel should spray. I haven't worked on one of those but, if it's anything like the old throttle body injectors, it comes right out and is easily replaced. I think I would start there.
Nope. That didn't do anything. I'm clueless on what to do next except purchase a reman spider injector assembly..
That's why I'm thinking it's stuck open. A new AC-Delco unit (217-2280) is about $100, but you can buy remanufactured ones for about half that. You can also buy a seal kit for it (217-3030), in case that's why it's bypassing.
Except that's tbi mine is cpi
