1994 4.3L Blazer Running Rough. All help is welcome!
Old Dec 10, 2012 | 07:59 AM
Farmer01's Avatar
Farmer01 is on a distinguished road
Next time, you should do some diagnosis before you replace all those parts.
The things that I replaced were either supposed to be, through advice, the source of the issue or already in need or replacement. For example, I replaced the coil after having it tested at 40% spark. I Replaced Cap and Rotor after removing them and discovering they were extremely corroded and eroded. I replaced the fuel injection because when I removed the plenum there was a small leak in one of the poppet lines. Things were done in order from least to most expensive. So, yes, things were diagnosed as I went along...just happens to be that none of them so far are the real original issue.
Moving on. I have replaced the MAP sensor, and the engine is in time. Truck has 293,000 miles on it but motor and tranny are new as of 50,000 Miles ago.
Have not checked exhaust yet.
Old Dec 11, 2012 | 04:34 PM
Farmer01's Avatar
I checked the exhaust for issues and it was all clear. It seems to me as if I have done everything within my power to diagnose the issue. Anybody have more experience or small details that might help solve? The only thing that I haven't looked into is replacing the ECU/ECM. Is that likely to be the issue?
pjrueve
Mar 19, 2014 05:25 PM
1995posjimmy
16
Mar 10, 2010 06:34 PM
sarmikgar
Jan 23, 2009 07:48 PM
kiwiblazer
Dec 2, 2008 10:56 PM
ken erestu
Headers, Intake, & Exhaust
Nov 27, 2006 02:46 PM
