-   -   1994 s10 blazer engine swap (https://blazerforum.com/forum/engine-transmission-35/1994-s10-blazer-engine-swap-44039/)
hammer395 May 2, 2010 09:42 PM
i just got a 94 s10 blazer with a bad engine and was gonna swap it with one from a 97. there the same engines (4.3 vortec) but they look different. could someone eplain why that is
Leeann_Bravada May 3, 2010 05:26 PM
Interchange
92-94
95
96+
Your options are a 92-94 CPI (VIN W) motor only. The '97 is not compatible without a lot of work. The 94 is an OBD 1 vehicle while the 97 is an OBD II vehicle. Sensors are different, etc.
hammer395 May 3, 2010 08:55 PM
ok thanks. would you happen to know if the enternals where the same so that maybe the parts could be used 2 fix up the 94 vortec
Leeann_Bravada May 3, 2010 08:57 PM
The heads are different, the injectors and manifold setup are different....
Umm, I'm not sure much interchanges.
hammer395 May 3, 2010 09:17 PM
dang. ok thanks
tyler-2tracking Sep 11, 2011 10:10 AM
now I have a 95 jimmy and i bought a 94 4.3l and everything hooked up the exact same. But now when I am tryin to start my truck I am not getting spark out of the coil to the distributor
