-   -   1995 4.3l V6 Vortec SPUTTERING/MISFIRE on acceleration (https://blazerforum.com/forum/engine-transmission-35/1995-4-3l-v6-vortec-sputtering-misfire-acceleration-70915/)
50lb_cat 05-24-2012 12:56 AM
Sounds like you got it covered. Its either the fuel pressure regulator or you have a leaking injectors. With that much of a drop I would suspect the regulator. Time to pull the plenum. It should be black and sooty, it its clean you know something is leaking. At that time you can test the regulator to determine if its the reg or injectors.
stephen5217 05-24-2012 01:29 AM
Is the regulator part of the spider? If I buy a new one would I just get the whole setup? Do you think that the fuel pump has anything to do with it?
50lb_cat 05-24-2012 10:56 AM
The reg. Is a different part from the spider. From the numbers the fuel pump is ok. If you want to change both the reg and spider I would reccommend getting a delphi MFI conversion from rockauto, they are less prone to failure.
50lb_cat 05-24-2012 10:57 AM
stephen5217 05-24-2012 11:27 AM
so the problem is most likely that? Anything else that could be wrong?
50lb_cat 05-24-2012 11:41 AM
Sorry about the double post, damn android phone lol. Your key on pressure is good so its not the pump. You have fast leakdown and that usally points to the regulator. Look down the throttle body, if the passenger side is very clean or shows signs of washing then that confirms it.
stephen5217 05-24-2012 09:01 PM
i looked into the engine and both sides seem the same. it does look pretty clean though... like silver splotches
50lb_cat 05-24-2012 10:47 PM
Take the plenum off so you can pinpoint the leak, but that's definetly where the leak is coming from.
stephen5217 05-24-2012 10:48 PM
I was trying out a few things today with the fuel pressure gauge, and it has gotten very severe with acceleration. My fuel pressure however stays consistent, until the engine dies and the key is still in the ON position, then the pressure bleeds out pretty quick. When I was driving it the engine seemed to be gasping right before it died, or when the RPM would drop super low like 500 then jump back up to 1500 (this is while idling in drive). Like a said before the inside of the intake manifold looks pretty clean, and it was more moist than before. I think I'll just replace the injector and pressure regulator. Anybody know what MFI conversion would work with the 1995 GMC jimmy 4.3l vortec v6 engine?
stephen5217 05-24-2012 10:52 PM
I saw this after I posted, I'll do that and make sure that it is there.
