1995 blazer 4.3 4wd, automatic 2dr
Old Apr 9, 2013 | 06:48 PM
scphill34's Avatar
scphill34 is on a distinguished road
Default 1995 blazer 4.3 4wd, automatic 2dr
replaced fuel pump
replaced nutkit and pressure regulator
Serviced tranni new fluid/filter
Relpaced shift soleniods in tranni
replaced 4wd switch in dash with new from NAPA store
replaced vacuum switch
checked vacuum lines no atf present
replaced input shaft seal serviced tcase
I need a schematic, wiring diagram or both to check for a bad wire. Any suggestions would be great. I don't want to burn up my tranni.
I think this comes from the previous owner running fuel completely out and smoking the fuel pump. The wire were literally black and the insulation crumbled. Lucky there was no exsplosion.
Thanks in advance steve
scphill34
Apr 22, 2013 08:59 PM
scphill34
Apr 10, 2013 02:36 PM
scphill34
Mar 26, 2013 07:09 PM
the Fllash
Jun 12, 2011 01:19 PM
RickBlazer
May 26, 2010 04:33 PM
