1995 Blazer CPFI Running Like Crap HELP
Old Feb 10, 2014 | 08:09 PM
Davesaylor250's Avatar
Davesaylor250 is on a distinguished road
Angry 1995 Blazer CPFI Running Like Crap HELP
I have got a 1995 Chevrolet Blazer 4.3 vortec, I have replaced TPS,IAC, EGR Valve, Plugs, Plug Wires Cap Rotor, Spider injector, Fuel line nut kit, Now my Problem is it is running very rough when I can get it to start it cranks for about 45 seconds to start has a misfire but cannot tell from what cyclinder NO Check engine light and I have vacume in the crankcase Please help I am ready to dynamite this thing.
Old Mar 6, 2014 | 08:43 AM
kerander's Avatar
kerander is an unknown quantity at this point
Did you clean out the gas recirculation system when you had the plenum off?
Did you make absolutely sure you put the plugs and wires back on in the correct order?
Have you checked the oxygen sensors?
You could try pulling and cleaning the fuel injectors, or using a good amount of chevron fuel treatment. Careful if you pull the injectors... they can be fragile.
Is your coolant level ok? When you pulled the plugs, did you notice any water or condensation in the cylinder? Noticed frothy oil when you change the oil?
You could try sending in fluid samples for analysis. Not that expensive now a days and I have heard positive things for cryptic problems like yours.
Old Mar 6, 2014 | 08:38 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
[QUOTE=kerander;621011]Did you clean out the gas recirculation system when you had the plenum off?
U should start by performing a fuel pressure test!:these trks are notorious for fuel issues.....there is a sticky on the forum telling u allu need to know to properly diagnose any issue with fuel system....
Old Mar 11, 2014 | 03:53 AM
Antne's Avatar
Antne is an unknown quantity at this point
Yes Start With The fuel Pressure Test, Then I Would Do A Compression Test As Well. My 95 Was recently Running The Same WaY ChangedMost Of The Same Parts. Fuel PrEssure Was Good But After A Compression Test Found One With No Pressure. And Ended Up Being A Broken Spring.
Old Mar 24, 2014 | 12:29 PM
07nhbpsi's Avatar
Well, did any of this help u solve the problem???
closer
Jan 17, 2012 10:15 PM
zakm0n
Jan 10, 2011 11:42 AM
paynebryan
Apr 17, 2010 11:53 PM
bwoodfire45
Dec 15, 2007 07:25 PM
crx_soldier
Dec 6, 2006 08:08 PM
